Coming up on Radio 1 at
Playing around with Buffers and Ring Modulation...
Page 1 of 1 [4 Posts]
Dr. Spankenstein
PostPosted: Tue Jun 12, 2007 8:44 am    Post subject: Playing around with Buffers and Ring Modulation... Reply with quote  Mark this post and the followings unread
Hello,
I'm currently trying my hand at Ring Modulation. Easy I thought, just multiply the audio by a SinOsc and I'm all set. Unfortunately that doesnt seem to be the case and I'm currently getting no sound out.
Where am I going wrong?
Code:
SndBuf Buffer1;
Gain Gain;
"File.wav" => Buffer1.read;
1 => Buffer1.gain;
3 => Gain.op; // So it multiplies the inputs (as described in manual)
SinOsc RingModulation;
1.0 => RingModulation.gain;
5000 => RingModulation.freq;
Buffer1 => RingModulation => Gain => dac;
2::second => now;
Thanks,
Rhys
chuckles
PostPosted: Tue Jun 12, 2007 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I get the same result as you. Even if I lower the freq. to 1000 Hz.
But if I rewrite it as below If I do this I hear what sounds like Ring Mod. But as I use 3000 then 5000 for the freq of the RM UG to 5000 the signal does fade out again. Maybe because of the noisy environment I'm in + my bad hearing. But give this way a try.
Code:
SndBuf Buffer1;
Gain Gain;
"Audio files/drumloop.wav" => Buffer1.read;
1 => Buffer1.gain;
              // (as described in manual)
3000 => RingModulation.freq;
RingModulation => Gain;
Buffer1 => Gain => dac;
2::second => now;
Dr. Spankenstein
PostPosted: Tue Jun 12, 2007 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I knew it would be my naff coding order..... Embarassed
Oh well... it works great now!
Thanks very much.
Rhys
kijjaz
PostPosted: Thu Jun 14, 2007 2:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh! Using Gain's .op = 3 as a multiplier for ringmod, that'd be my easiest way also.
